Activity Forums Adobe After Effects Expressions Write or Change Expressions for many layers at the same time. Is this not possible?
  • Write or Change Expressions for many layers at the same time. Is this not possible?
    Posted by Arne Münch on January 12, 2012 at 4:59 pm
    Hi Community
    I ask myself and you why when I select multiple layers and then for example press “s” for scale and select all “scales” again and then I press alt + click the stopwatch and write some expression, only one layer gets the expression. The other layers only get a standard expression “transform.scale”.
    What if I have 50 layers for example and want to change a expression for all of them, do I have to copy and paste the expression 50 times? Is there no way to change all of them at once?
    Thanks for replies.
    P.S.
    I tested with AE_CS5
    Arne Münch replied 14 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 12, 2012 at 5:27 pm
    After you edit the expression, make sure the property is selected, Edit>Copy Expression Only, select all the other layers, Edit>Paste.
    Dan
  • Arne Münch
    January 12, 2012 at 5:44 pm
    Thats it, I thank you so much, you saved me a lot of hours I guess..
