Activity Forums Adobe After Effects write-on with paths
  • write-on with paths
    Posted by David Decay on July 20, 2006 at 12:12 pm
    hi out there,
    if done an artwork in illustrator which has some brush lines in it (paths)
    now i want to reveal these lines in ae with write on effect, if managed once, but now icant
    bring in the path of illustr in ae anymore.
    anyone could help me
    thanx
    David Decay replied 20 years, 2 months ago 2 Members · 3 Replies
  • Lars Bunch
    July 20, 2006 at 1:57 pm
    In Illustrator, select the paths you want to put into AE. Switch to AE and, in a comp with a solid in it, paste the illustrator paths. They should show up as mask paths in AE.
    You should then be able to apply a stroke or write on effet to them.
    If this doesn’t work, let us know what versions of software you are running and if it is under windows or Mac.
    Hope this helps,
    Lars
  • David Decay
    July 20, 2006 at 2:09 pm
    hi lars,
    im copying the paths in ill, paste them in ae, what i get are pretty much masks on my .psd,
    but how do i get them in the brush-position of the write-on effect?
    using win xp, and ae 6.5
    thanxs
  • David Decay
    July 21, 2006 at 9:21 am
    thanx a lot guys, i got it!
    my mistake was that i applied a brushstroke to the path in illustrator, and then coppied the brush,which is in fact very much masks, that confused me because i had circa 100 masks in ae.
    the right way is to copy only the path in illusrtator(so you get one path)and bring this one to ae, then it works, as you said guys!
    thanxs for the great forum(im from austria, greatful to get some prof. help)
