Activity › Forums › Adobe After Effects Expressions › Write-on Text from SourceText via Slider. Pos Y slide-up via Expression selector
  • Write-on Text from SourceText via Slider. Pos Y slide-up via Expression selector
    Posted by Gerald mark Soto on March 11, 2025 at 5:27 pm
    Im currently using this expression with an effect slider to reveal one letter at a time via the Source Text paramter:
    s = effect(“Slider Control”)(“Slider”).value;
    value.substring(0, s);
    My question is: I would like to have each letter Position Y slide up with ease about 30 pixels as each letter is being revealed via the effect slider. I assume this needs to be done with a position text animator via the expression selector. But whar exactly should that be? I can seems to get a proper working expression . Help. and thank you.
    Gerald mark Soto replied 1 year, 6 months ago 3 Members · 12 Replies
  • 12 Replies
  • Dan Ebberts
    March 11, 2025 at 6:02 pm
    You could add a Position Animator and set its Position value to 0,30. Add an Expression Selector, delete the Range Selector, and use this expression for the Expression Selector’s Amount property:
    s = effect("Slider Control")("Slider").value;
    ease(s,textIndex,textIndex+1,100,0)
    It uses the same slider as your Source Text expression.
  • Gerald mark Soto
    March 11, 2025 at 6:14 pm
    It doesnt exactly work. It snaps into position rather than animate slide up. any ideas sir?
  • Gerald mark Soto
    March 11, 2025 at 6:18 pm
    this is sorta working but it stops animating after i run out of keyframes.
    s = Math.round(effect(“Text_Reveal”)(“Slider”).value);
    if (textIndex == s)
    70
    else if (textIndex < s)
    0
    else
    100
  • Gerald mark Soto
    March 11, 2025 at 6:23 pm
    Oh never mind. i ram previewed my expression and its moving so slow and at like 4 frames per second. it definitely did not work.
  • Yoan Boisjoli
    March 11, 2025 at 6:38 pm
    Hey Gerald, don’t know if it can help but this is pretty useful and I think it might help you out!
  • Gerald mark Soto
    Ok. so back to the expression. that i was using. it actually does work. but the animation poses at each keyframe. you need to try it out your self to see what I mean. essentially this expression works but each key letter should play out the animation independently as it appears. any ideas?
    s = Math.round(effect("Slider Control")("Slider").value);
    fadeDuration = 10;
    if (textIndex < s - fadeDuration) {
    0;
    } else if (textIndex >= s) {
    100;
    } else {
    ease(textIndex, s - fadeDuration, s, 0, 100);
  • Gerald mark Soto
    March 11, 2025 at 6:42 pm
    text evo would not be an option. I require the SourceRectTime of the text layer. I eventually want this type layer to drive the size of a box that it will be on top of. You cant use TextEvo for that.
  • Dan Ebberts
    March 11, 2025 at 7:42 pm
    It works for me if I change your fadeDuration from 10 to .333.
  • Gerald mark Soto
    March 11, 2025 at 7:51 pm
    its not working for me because im using toggle hold keyframes. Im recreating a typing style animation letter by letter with pauses in-between some letters. so the animation stops after each keyframe.
  • Gerald mark Soto
    March 11, 2025 at 8:02 pm
    Yup thats the definitely the problem. Is there anyway for this to work with toggle hold keyframes? so i can create a type writer style animation?
