Activity Forums Adobe After Effects “write on” text effect
  • “write on” text effect
    Posted by Kayla on February 12, 2007 at 4:50 pm
    Hi, how would I do a simple write on effect (without using a mask)? I want it to look like cursive writing on…Thanks…
    Markh replied 19 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Mylenium
    February 12, 2007 at 5:16 pm
    [molly] “Hi, how would I do a simple write on effect (without using a mask)? I want it to look like cursive writing on…Thanks…”
    Not really. You can try a sinple linear wipe or combinations of multiple instances of said effect, but it’s not going to look too convincing. Some things simply cannot be had easily.
    Mylenium
    [Pour Myl
  • Kevin Camp
    February 12, 2007 at 5:20 pm
    you could use vector paint to keyframe in a stroke over your text. then set the composite paint setting to ‘as matte.’ it takes time, but you can get good results.
  • Kevin Camp
    February 12, 2007 at 5:24 pm
    also, i beleive, Aharon Rabinowitz did a nice tutorial here on animating a signature. check that out, i think it would help you a lot.
  • Kayla
    February 12, 2007 at 5:31 pm
    thanks, when you say linear wipe, is there an effect/plug in for that? or do you mean a wipe with a mask? Thanks…
  • Mike Clasby
    February 12, 2007 at 6:07 pm
  • David Bogie
    February 12, 2007 at 8:55 pm
    Masking or write-on with the paint effects. Easy but tedious.
    The critical thing with cursive is knowing form the start that crosses, dots, bars and any overlaps must be separate layers, separate paints, or separate masks.
    bogiesan
  • Markh
    February 12, 2007 at 10:34 pm
    The cleanest way is to use Photoshop, type your logo with your favorite font, break it down into layers, then import the PSD with its layers into After Effects. Use the write-on effect to reveal each layer. It takes a little time but is really clean.
    You’ll get the idea if you watch Jayse’s (excellent) video on making elements grow.
    https://www.creativecow.net/articles/hansen_jaysen/growing/growing_things.html
