Write on / stroke effect. Path animation problem
I’m getting crazy to find the way to resolve this, hope that you can help me.
Is there a way to link the mask path to the brush position in the write on effect without copying and pasting the mask path on to the brush position? I know that I could use the stroke effect but I need to have different sizes along the path and stroke effect doesn’t allow me to do that.
I need to animate the path before this is animated the first time. Is there another effect that I could use? The only way that i’ve find to animate the path is to put puppets on it, but it’s not the effect that i want.
I attach some pictures to help you understand
Thank you
