Activity Forums Adobe After Effects Write on help… PLEASE
  • Write on help… PLEASE
    Posted by Fabiano Peres on July 20, 2006 at 3:20 pm
    Hi there
    I’m trying to use the write on effect, but when I copy the mask shape and paste it into the write one position, it goes to a different part of the screen. It’s animating correctly, but always lots os pixels alway from the maks place. What do I do???
    Jacob Wessler replied 20 years, 2 months ago 2 Members · 2 Replies
  • Fabiano Peres
    July 20, 2006 at 5:56 pm
    Thank you so so so so so much Dave. It worked very well, now I can work.
  • Jacob Wessler
    July 20, 2006 at 6:36 pm
    I have had this same problem before too. Here was my workaround (not nearly as productive and time-saving as Mr. LaRonde’s, but academically, a little more challenging).
    First, I had to duplicate the write-on effect to use as a source.
    Then, in the original write on, I wrote an expression that used the position of the brush from the duplicated effect and then adjusted the x,y coordinate of the brush position until it matched that of my mask. A little trial and error, but ultimately, it worked like a charm.
    HOWEVER, now I know how to make it work WITHOUT spending an extra 20 minutes setting things up.
    Live and learn, right??
    Jacob
