Activity Forums Adobe After Effects write on effect over a 90 degree angle
  • write on effect over a 90 degree angle
    Posted by Timi Boose on August 18, 2014 at 11:06 pm
    what is the proper way to do this – I’m animating light rays bouncing off a window.
    When there is an angle, it seems to cause a problem – Do you put each line that makes the angle on a separate layer and do a separate write-on effect for each one? Or do it with a mask.
    I’ve been messing around with these ideas – wondering how you professionals would do it
    Timi Boose replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
