Activity Forums Adobe After Effects write on effect issues
  • write on effect issues
    Posted by Timi Boose on June 28, 2013 at 1:51 am
    HI….I’m trying to draw simple drawings around a video – it takes soo long! So anyway – I succumbed to using the write on method since the screen capture method I tried had problems.
    I drew a really simple drawing in photoshop – now I’ve spent 40 minutes doing the write on effect over it but for some reason when I am 90 percent done, it’s not working anymore – I can’t see the path anymore. I’m just painting over original and then before I render , I’ll swiitch it to reveal original. I don’t know if there is a button or something I clicked on accident? If I click B for brush it just paints over the top – I can’t figure out how to continue my path. I’ve even restarted the computer.
    Any suggestions?
    Stephen Smith replied 13 years, 2 months ago 4 Members · 6 Replies
  • Timi Boose
    June 28, 2013 at 3:37 am
    helloooo?
  • John Cuevas
    June 28, 2013 at 12:05 pm
    Post a screen grab please so we can see how you set up your comp and effect.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Stephen Smith
    July 1, 2013 at 3:37 pm
    Are you doing the method outline in this tutorial: https://www.videocopilot.net/tutorials/graffiti_writing/
    Stephen Smith – Follow me on Behance
    Utah Video Productions
    Check out my Vimeo page
  • Eric Chard
    July 2, 2013 at 7:16 pm
    R U trying just to draw a static outline, or have the outline animate around the figure?
    “Putting the HARM in ‘harmonica’ since 2005.”
  • Timi Boose
    July 3, 2013 at 6:42 pm
    I did try the Video Copilot method using Generate Stroke on another part of my project which seems a little easier than write-on. Still haven’t figured out why write-on only goes so far and then starts erasing itself. I’ll get back to it soon and probably ask a more specific question.
  • Stephen Smith
    July 3, 2013 at 6:50 pm
    Is End set to 100 and Start set to 0 while you are creating your masks?
