Activity Forums Adobe After Effects Write On Effect Issue
  • Write On Effect Issue
    Posted by Phil Lebeau on June 2, 2009 at 8:57 pm
    I am using After Effects CS4. I imported some “swoosh” graphics from Illustrator as Cropped Comp into After Effects.
    In AE – I add a write on effect to one of the swooshes to make it look like it paints on.
    BUT – when I scale up or rasterize that swoosh, the paint effect doesn’t follow.
    I spend alot of time doing the write on effect, but I cant scale it up.
    Any thoughts?
    Ken Knowles replied 17 years, 3 months ago 3 Members · 2 Replies
  • Darby Edelen
    June 2, 2009 at 10:47 pm
    Try using the write-on effect on a solid layer above the layer you’re trying to reveal, parent the solid to the layer (make sure they’re the same size and that the write-on effect lines up properly), then set your layer to use the solid as an alpha track matte.
    Darby Edelen
  • Ken Knowles
    June 3, 2009 at 8:45 pm
    How did you use the write-on effect to reveal the swoosh?
    Ken Knowles
    Knowles-McNiff
