Activity › Forums › Adobe After Effects › Write on effect
Write on effect
Posted by Jack Stewart on January 18, 2013 at 10:12 amHey guys
I have been having some trouble getting the Write-on effect to work. I seem to be doing everything correct but I can’t get the brush position to move along the path.
I have tried it in another composition doing the same thing and it works but in other compositions it won’t. Why is this?
You can see from the image that I have uploaded that the brush position should be further along the path. The timeline indicator position shows how far into the key frames it is on the line.
Something is going wrong with the brush position. Please can you help.
Many thanks,
JackVishesh Arora replied 13 years, 8 months ago 3 Members · 8 Replies -
Jack Stewart
January 18, 2013 at 12:20 pmHang on After Effects community. I think I have managed to find the solution for you all. So if there are any more noob designers out there struggling with the write-on effect here is what I think you need to do.
You need to pre-compose the asset that you want to write-on. The reason why you need to do this is because if its not pre-composed when you copy the path and then paste it onto the brush position your pasting path coordinates that are in a much larger space than what you need. The brush is still moving but its probably off the canvas, out of view.
So please correct me if I am wrong experts as I am still new to this but I hope this helps people who end up with the same problem to solve.
Cheers,
Jack -
Roland R. kahlenberg
January 18, 2013 at 2:16 pmAs long as the source and target layers have identical resolutions, there is no requirement for precomping.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Jack Stewart
January 18, 2013 at 2:38 pm -
Vishesh Arora
January 19, 2013 at 1:13 pmJack
See the Image Below:
You can see the difference in Dimensions of the Graphic layer and your Comp which is creating problem for Write-On Effect.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Jack Stewart
January 22, 2013 at 9:58 amHey
Thank you ever so much for the informative responses here.
I was still having some trouble but I think this is because the file I was trying to apply write-on to was an imported illustrator file. I’m not sure why.
I have since found that by pre-comping the illustrator file and then applying the effect to the pre-comp works every time.
Maybe there is no need to do this but it has been the only solution that is working.
Thanks ever so much for your help guys!
Regards,
Jack -
Vishesh Arora
January 22, 2013 at 10:06 amJack
Another workaround, make your Document size(in Illustrator) equal to the Comp size you want in After effects and then import your Illustrator file.
Vishesh Arora
Films RajendraBlog:
Jack Stewart
January 22, 2013 at 10:46 amHey Vishesh
I forgot to mention anything about illustrator before now, but yeah that makes perfect sense!
My comp for the illustrator files is 5443 x 3062
and my output resolution is 1920 x 1080.
So thats explains it.
Thanks for helping me get to the bottom of this.
Jack
Vishesh Arora
January 22, 2013 at 11:02 amAnytime Jack
Vishesh Arora
Films RajendraBlog:
