Activity Forums Adobe After Effects Write-on brush size?
  • Write-on brush size?
    Posted by Ron Dylewski on April 16, 2008 at 5:00 pm
    Hi –
    I am trying to do a simple write-on, using that effect. At certain points in the effect, I need to make the brush size smaller or larger, however, when I attempt to do this, the brush size changes globally across the entire length of the effect, even though there are key frames for each. Am I missing something simple here?
    Thanks.
    Ron
    Mike Clasby replied 18 years, 4 months ago 2 Members · 1 Reply
  • Mike Clasby
    April 16, 2008 at 5:11 pm
    I think Trapecode’s 3D Stroke is the only one where you can control the taper of a Stroke.
