Activity Forums Apple Motion Write on behaviour issue
  • Write on behaviour issue
    Posted by Peter Gordon on June 29, 2012 at 7:54 am
    I have just tried to do a paint stroke that is revealing text . I am using an image mask to do this. I created a zigzag line with the line shape tool and then applied a write on behaviour to the shape. Following this I created an image mask on the shape (pain stroke) and put the text in the source well. My problem is for some reason my pain stroke will write on but will not erase afterwards. This is in spite of the fact I have selected it as the designated option in the HUD. Is it because I am using an image mask that is causing it to only write on but not erase? I have since tried to use the paint tool and also a shape with a write on effect and both are not erasing as they should. Any ideas?
    Mark Spencer replied 14 years, 2 months ago 2 Members · 1 Reply
  • Mark Spencer
    June 29, 2012 at 12:42 pm
    You need to put your image mask on the text (or on a group containing just the text), then put the paint stroke in the well in the HUD. You are masking the text with the paint stroke, not the other way around.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
