Activity › Forums › Apple Motion › write on
write on
Posted by Jodi Binstock on April 28, 2010 at 1:36 amStephen Smith replied 16 years, 5 months ago 3 Members · 4 Replies -
Mark Spencer
April 28, 2010 at 1:56 amDo you have the artwork as separate layers? If not, you’ll want to break out the parts you want to write on, then cover them with paint strokes, animate the paint strokes with the write-on behavior, and use those paint strokes as an image mask applied to your yellow lines.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Jodi Binstock
April 28, 2010 at 4:51 amSo great. Thank you. How do I use the paint strokes as an image mask. I managed to draw the tree (It drew white) I managed to write on the paint strokes, but what I can’t yet figure out is how to make the draw on the yellow image behind it.
Thanks.
Jodi
Mark Spencer
April 28, 2010 at 1:07 pmSelect the yellow image. Chose Object > Add Image Mask. Drag your paint stroke to the well in the HUD.
Mark Spencer
Stephen Smith
April 28, 2010 at 2:13 pmHere is a video tutorial with an example of how to use an image mask. It is in the middle of the Creating a Hologram tutorial. Best of luck.
Check out my Motion Tutorials
