Activity Forums Adobe After Effects Wrapping some text around a cylinder and rotating it??
  • Wrapping some text around a cylinder and rotating it??
    Posted by Gizmo1990 on February 12, 2006 at 2:36 pm
    I’d like to create some text spinning around an imaginary cylinder. I’m sure people here will know what I mean. Kinda like wrapping a word around a invisible cylinder then rotating it around its Y axis.
    Unfortunately I’m unsure how to go about this? Is there a method/function in AE(7) which would provide this ability quickly and easily? Or am I going to be forced to create the effect in Maya and comp it in?
    P.s. I don’t know if 3D Invigorator does this but I can’t check as the classic version I downloaded won’t work with my (trial) ae7 for some reason?? So answers using just vanila ae please.
    Any help really appreciated.
    Gizmo1990 replied 20 years, 6 months ago 2 Members · 4 Replies
  • Chris Smith
    February 12, 2006 at 3:28 pm
    Just use CC Cylinder. It’s came with AE 6.5 and 7.0.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Gizmo1990
    February 12, 2006 at 4:04 pm
    Thanks for the reply Chris.
    Unfortunately I don’t appear to have CC cylinder?
    Is it an effect only included in the retail version of 7? I’m using the trial of currently, I’ll upgrade when I can afford it after this job.
    If it is I can’t go back to 6.0 as my version is 5.5.
    Is there another way to do this perhaps?
  • Chris Smith
    February 12, 2006 at 4:14 pm
    Not sure about the version you have. But on the standard upgrade or full install disc there is a folder called Cycore. Once installed it adds (i’m guessing) about 30 some-odd effects to AE. They all have the prefix “CC”. CC Cylinder does exactly what you’re wanting.
    Chris Smith
  • Gizmo1990
    February 12, 2006 at 6:03 pm
    Thanks Chris.
    Just found out it’s not in the trial version. Could download the demo of from Cycore but there’s a lovely watermark emblazened across its output…
