Activity › Forums › Maxon Cinema 4D › Wrapping extruded vector around curved surface
Posted by Rodolfo Guedes on June 25, 2009 at 7:44 pmHello,
I’m trying to make an extruded vector to have the same curvature of an oil tank primitive.
Anyone can help me?
John Hammond replied 17 years, 3 months ago 4 Members · 7 Replies -
Brian Jones
June 26, 2009 at 1:40 amaround the middle part of the tank? Wrap deformer? or are you trying to include the caps of the tank too?
Rodolfo Guedes
June 26, 2009 at 10:31 amI wanted to bend the extrusion so that it followed the curvature of the spherical part of the oil tank, the top.
The idea is to use the oil tank primitve with a little height so that it looks like a pin. Then, the extrusion would stick out in a way that its height would the same all over the top of the pin, following the curvature that the pin has..
It may sound a bit complex, but its really simple..
I’ve tried the wrap object, but it’s too complicated to get the exact curvature, i’ve tried the spline the spline wrap, but i can’t make the curvature for both x and y axis. -
John Hammond
June 26, 2009 at 3:14 pmHi,
There’s a ‘Project’ function located at: Structure/Edit spline/Project.
If you take a spline and place it in front of a sphere, and choose this option, then choose your axis in the arrtibutes manager and hit Apply, it should project it onto the surface of the sphere. You need enough subdivisions in your objects to get nice results.
Could that help?
John
Rodolfo Guedes
June 26, 2009 at 4:19 pmThat’s almost what i’m looking for, but instead of a spline,i’m trying to put an extrusion.. Picture a pin with some text beveled..
Rodolfo Guedes
June 26, 2009 at 4:23 pmI’m sorry.. I’ve talked before i’ve tried.. It works perfectly. I just had to extrude the spline and it fited.. Thank you so much
Ronaldo Montalvo
June 26, 2009 at 6:12 pmHey John, I’ve been trying to do this but am having trouble. Your directions and the manual indicate “After choosing the Project function, a dialog opens. Use this dialog to choose the type of projection”, but when I do that no dialog opens, nothing happens, nothing in the attributes manager. The option is there and available, I’m using a plane and an editable open bezier spline in front. I’m using C4D R10. I’m obviously missing something, any idea what?
John Hammond
June 29, 2009 at 9:47 amHey,
Sorry I don’t know.I managed to get it to work, maybe you need to make everything editable or something.. really don’t know so maybe re post now you know what tool you are after..
