Activity Forums Adobe Media Encoder Would like to output one timeline to a single codec/format, but to multiple filenames, without re-encoding each file
  • Would like to output one timeline to a single codec/format, but to multiple filenames, without re-encoding each file
    Posted by Matt Goff on May 16, 2013 at 12:03 am
    Hello everyone.
    A newb to the forum, and recent FCP 7 to Premiere convert.
    Issue-
    I have to output multiple versions of the same sequence.
    The only change to each encoding instance is the filename.
    Goal-
    enter multiple filenames to output, but only encode once.
    so-
    exciting_foo sequence needs to be rendered out in say h.264 with all the same settings.
    but i need say 8 versions of this same file, but with 8 different names.
    i tried ‘duplicate’ in media encoder, and ‘add output’, but it re-encodes for each instance.
    i can find plenty of batch renaming apps, etc, but none that will duplicate and rename.
    i did search the forums for about an hour, but couldn’t find anything helpful, if i missed a thread that covers this a link to it would be great.
    Running CS6 on a Mac
    Cheers.
    Kris Merkel replied 13 years, 3 months ago 2 Members · 1 Reply
  • Kris Merkel
    May 16, 2013 at 12:55 am
    Pardon if I didn’t understand the quandary, but can you not just copy the file 7 times in your output folder and give each one a unique name?
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
