Activity Forums Avid Media Composer Would like to export a frame higher than 72 dpi.
  • Would like to export a frame higher than 72 dpi.
    Posted by Blazen on July 3, 2007 at 6:01 pm
    I am trying to export frames from my timeline in AVID to Photoshop so that I can use them in a press kit. Every time I export a frame/graphic, no matter the type of graphic (jpeg, tif, psd, etc), it exports at 72 dpi and I need it to export at 300 dpi. Is there a way to change the resolution setting?
    I am using AVID Xpress Pro HD v5 2.4.
    Blazen replied 19 years, 2 months ago 2 Members · 2 Replies
  • Seanski44
    July 3, 2007 at 7:34 pm
    I don’t think you’re able to.
    Bear in mind that dpi is just a ratio between the print size and the pixels your image is made up from. So your image is probably about 720×480 (NTSC?) (Unless you’re high def or PAL or whatever) – So, if you want a 300dpi image from the 720×480 image, you can either change the dpi in photoshop (or any reasonable print package) and end up with a tiny image or resample the image in the print package and end up with a largish image at high dpi but quite poor quality.
    So in a nutshell, the screen dpi is 72, so you can’t get any more than that from avid. you can ‘upsample’ in a third party application, but that’s about it.
    hope that helps somehow!!
  • Blazen
    July 3, 2007 at 8:29 pm
    This was a Mini-DV project so your answer confirms my suspicions. I will just have to take more production stills in the future. Thank you!
