Activity Forums VEGAS Pro Would Adding Extra RAM Help This Issue?
  • Would Adding Extra RAM Help This Issue?
    Posted by Phil Davies on July 19, 2009 at 1:02 pm
    Just started working with HD footage in Vegas Moveie Studio Platinum 7.
    It’s HDV (not AVCHD) and for the most part handles okay. But I can’t preview transitions in the preview window – even on “draft” view…
    The footage pauses during the transition and then skips to catch up after it’s complete. It’s very difficult to judge fades etc.
    My specs are Pentium core 2 due (2.1mhz) with bog standard graphics card (Radeon x1600) and 2GB RAM. Would adding extra RAM / better graphics card help or are there other limitations that would negate this?
    Phil.
    Phil Davies replied 17 years, 2 months ago 3 Members · 4 Replies
  • John Rofrano
    July 19, 2009 at 1:09 pm
    No. Vegas doesn’t take advantage of any graphics card processing and more RAM will not help either. HDV playback is CPU bound and a 2.1Ghz dual core is below Sony’s specs of 2.8GHz for working with HD. You can make a timeline selection around the transition and use Shift+B to perform a RAM preview if you want to see a particular transition at full frame rates.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Norman Willis
    July 19, 2009 at 5:08 pm
    Hi John.
    Just for my own edification, would Cineform NeoScene help him?
    Cineform lists its minimum specs as:
    Min: Core 2 Duo 2GHz
    Preferred: Core i7
    https://www.cineform.com/neoscene/requirements.php
    It might be cheaper for him than purchasing a new machine.
    Just a thought.
  • John Rofrano
    July 19, 2009 at 5:25 pm
    That depends on several things, one of them being that Neo Scene cost as much as his Vegas Movie Studio Platinum did! 😉
    I didn’t catch the fact at first that he is using Vegas Movie Studio Platinum 7 and the current version is 9. Back in the VMSP 7 days it didn’t handle HDV very well but Sony has been doing lots of things to improve on that. The first thing I would do is download the trial of VMSP 9 and see if it handles HDV any better. It probably will and that may be all he needs. If that doesn’t work and he can spring for another $99, I would download the trial of Neo Scene and see if his PC can handle CineForm any better. That would be my second choice.
    The good news is that they both have trials so there is nothing to loose here.
    ~jr
  • Phil Davies
    July 19, 2009 at 9:08 pm
    Thanks guys very helpful.
    I would actually consider getting Vegas Pro – so I can render straight to mp4 (my custom button is greyed out). I’ll try the trial version first though.
