Activity › Forums › VEGAS Pro › Worse quality by saving file 2 times?
  • Worse quality by saving file 2 times?
    Posted by Alexander Hellsten on December 21, 2009 at 11:59 pm
    Hi, I’m currently working on a project but I got a problem. The current videfiles are all too big, like 6gb for a 10 secs long clip. So what I want to do is to save the file in sony vegas with the settings i’m going to use for the final editing. I’ll save it, and therefor I’ll get a lot smaller size of the file. Now, my question is; I’ll save it once, but later when I have all the clips I need I’ll have to import them once again to sony vegas, edit the movie and then save it again. Will it make the quality worse if you use and save a clip two times in sony vegas? Or it wont do any damage since im using the same project settings?
    please help me, I just wanna reduce the sizes of the files, but not reducing the quality! 😛
    Alexander Hellsten replied 16 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Kristofar Rieleef
    December 22, 2009 at 1:13 am
    Try finding out what kind of files you are using and post the info, so people can get a better understanding of what you’re using. I’d suggest rendering the files to .m2t if they are HD.
  • John Rofrano
    December 22, 2009 at 2:51 am
    As Kris said, it depends on the codec that you are planning to use but in general, the answer to your question is: Yes, by rendering to make the file size smaller you will both loose quality and make it harder to edit. Then rendering again you will loose more quality but how much depends on the render type.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    December 22, 2009 at 4:53 am
    RENDERING a file doesn’t usually make it smaller, but ENCODING it does. You can RENDER an AVI file many times recursively before you start seeing any degradation of the image, but every encode to reduce file size will also reduce quality.
    Don’t confuse encoding with rendering, notwithstanding that Sony puts both in the “Render As” menu.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Alexander Hellsten
    December 22, 2009 at 10:35 am
    ok, thanks guys for your answers. I guess I’d give you seme more information. I’m making a fragmovie of CSS, and are recording the first video file as avi. When I render it in vegas I’ll choose avi, 1280×720, 30 fps, pixel aspect ratio 1, field order none, full-resoulotion rendering quality best (to get motion blur). These are the settings I’m using. Now if I would save one of my 10gb’s clips here with these settings, it will reduce alot. But then later I’d have have to use it again in vegas and render it once again…
  • John Rofrano
    December 22, 2009 at 3:01 pm
    It all depends on what codec you are using to make the AVI file and if the codec is lossy or lossless. If it’s lossy, you will lose quality. How much depends on the type of compression the encoder uses. Intraframe compression like DV and Cineform will hold up much better that interframe encoding like MPEG and DivX.
    Let’s get back to your original statement:
    The only way to do this is to use a codec that is lossless. Both Huffyuv and Lagarith are lossless codecs that are free. They still produce large files but they are smaller than uncompressed files.
    You didn’t say what codec you are using to capture your video. Is it FRAPS? I would convert FRAPS to Lagarith. if the files are still too big, then you have a decision to make. If you want them smaller, you must be willing to lose quality. Otherwise I suggest you simply buy another hard drive. They are cheap and a much better solution that sacrificing quality.
    ~jr
    December 23, 2009 at 2:39 pm
    I’m not using fraps to convert my material to avi, I’m using the source ingame stuff startmovie that reocords to frames, and then I later make them to avi in Vitrual Dub. What codec im using? If you mean the last compressing I’m doing it to x264, but thats after sony vegas so doesn’t belong to this part I guess.
  • John Rofrano
    December 23, 2009 at 9:32 pm
    Are you saying that the games records as a series of images and then you make them an AVI in VirtualDub? You can do this right in Vegas. What codec do you use to save it in VirtualDub? If you are rendering uncompressed then try using the Lagarith codec to get smaller file sizes and no loss.
    ~jr
    December 26, 2009 at 4:27 pm
    Okey, so earlier I’ve used picked “uncompressed” in vitrual dub, because I didn’t know what codec to use which woulnd’t make me loose the good quality. So If I instead use Huffrith or Lagarith it would for sure compressing it and keep the quality to 100%?
