Activity Forums Adobe Premiere Pro Worlflow Question
  • Worlflow Question
    Posted by Roberto Cerini on June 26, 2009 at 11:09 am
    This is a cross post, but I am not sure which of the two forums this should fit into.
    Hi – I have a workflow question. I have two scenarios I am trying to figure out.
    1. Video and Audio is recorded into main camcorder
    2. Video is recorded into camcorder (obviously) and audio in separate system (DAW)
    Option 1.:
    I plan on editing the audio in my DAW (Nuendo). Should I first edit the entire video sequence in Premiere so that the audio gets spliced accordingly, then export the audio, import it into my DAW (Nuendo) edit it and re assemble in Premiere?
    Option 2.:
    Should I import the audio into Premiere, line it up with the video, do all the splicing, export the audio, edit it with the DAW and re assemble it in Premiere? I figured this way the audio will get spliced with the video. Or should I first edit the audio and then bring it into Premiere for splicing? Or does it really matter?
    Roberto Cerini
    https://www.robertocerini.com
    Roberto Cerini replied 17 years, 3 months ago 2 Members · 2 Replies
  • Tim Kolb
    June 26, 2009 at 1:06 pm
    I’d line up the audio with the video and output one master audio track…that way when you go into your digital audio workstation, you’re working with only what you need.
    I usually bring the edited video in for reference as well in these circumstances.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Roberto Cerini
    June 26, 2009 at 1:24 pm
    Thanks Tim. I’m thinking that would be the cleanest way to keep everything aligned correctly.
    Roberto Cerini
