Activity › Forums › Adobe After Effects › World map on lower third
Posted by John Mark on September 16, 2012 at 11:47 pmI want to achieve this look were the world is placed on the right of the lower third.
Take a look at the picture I uploaded.
https://f1.creativecow.net/4669/world-on-lower-third?uploaded=fileA News Graphic Lover
John Mark replied 13 years, 12 months ago 4 Members · 9 Replies -
Tom Daigon
September 17, 2012 at 1:18 amI didnt download your file , but I thought I would share this link as maybe something you could use in your graphic.
https://www.videocopilot.net/tutorials/the_blue_planet/
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
John Mark
September 17, 2012 at 1:55 amI need to accomplish the world that was shown in the file i download to see if i could achieve the same look. Could you download the file to see if I can do this
Thanks for the website I’ll have a look at it.
Tom Daigon
September 17, 2012 at 2:09 amSorry, I dont download files from sites Im not familiar with 😀 If you could post the animation to You Tube or Vimeo Id be glad to look at it.
Tom Daigon
HP Z820 Dual 2687
64GB ram
John Cuevas
September 17, 2012 at 2:14 amAre you looking to create the world or just the placement of it? in a lower third? Do you already have a world graphic?
Tom, the file is just a .png, i downloaded and it’s safe.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Tom Daigon
September 17, 2012 at 2:26 amThanks JC.
John Mark. The tutorial I linked you to would work. You could even have the world spinning, which would look very cool.
Tom Daigon
HP Z820 Dual 2687
64GB ram
John Mark
September 17, 2012 at 2:56 amJust the placement of it, and I dont have any world graphics to start with any ideas on a similar one just like in the lower third. The world rotates as well, have a look.
https://www.youtube.com/watch?v=mEi_1wu-zY4&feature=plcp
Amit Parekh
September 17, 2012 at 8:56 amJust gonna suggest something but it might not work. If you have the graphic and stuff you want to use, position it where you want and then use a mask to get rid of the bits you don’t want. I’m new to AE so this may or may not work.
Hope it helps,
Ak. -
John Cuevas
September 17, 2012 at 2:35 pmTake a look at the tutorial Mark linked(or the Michael Park one in my link). Once you complete that you would be able to create your own rotating planet. (In my sample project, full credit goes to Michael Park for the rotating globe—-Creating a Realistic 3d Earth using only AE)
Create a new composition and call it “Lower Third”
Step 1 is to create a solid (cntl + y) and mask it, name this layer the “lower third BKG”. Duplicate the layer, name it “lower third mask”, place it on the top of the layer stack and change it’s mode to “Stencil Alpha”
Take the planet composition and drop it into the “Lower Third” composition. Scale it down and move to the bottom right corner. Place it below the “lower third mask” layer.
Finally you would make add the lines, text and gradient to your layer order, placing everything below the stencil. The stencil creates a boundary for every layer placed below it. In my example I added a linear wipe to the stencil so that the lower third wipes on to the screen.
My quick example project: 4670_lowerthirdproject.zip
John Mark
September 17, 2012 at 10:06 pmThank you all for the help, and thanks JC for the steps and example project.
