Activity › Forums › Adobe After Effects › world lit by candle light
Posted by Melissa Kern on February 15, 2008 at 4:58 amhow would I make it look as if my scene were lit by candle light? I am currently working in AE 7. thanks
Darby Edelen replied 18 years, 6 months ago 4 Members · 4 Replies -
Simon Bonner
February 15, 2008 at 2:23 pm -
Melissa Kern
February 15, 2008 at 2:48 pmit’s a 3D scene, there are actors that I green screened and dropped into what is basically a diorama (stacked layers as back ground, etc…)..
Steve Roberts
February 15, 2008 at 3:47 pmIf you are using a light, make it a warm colour and apply a wiggle expression (with numbers for just the freq & amp, omit the rest) to the light’s position or point of interest so the shadows wiggfle around a bit.
That’s one way …
Darby Edelen
February 15, 2008 at 7:12 pm[Steve Roberts] “If you are using a light, make it a warm colour and apply a wiggle expression (with numbers for just the freq & amp, omit the rest) to the light’s position or point of interest so the shadows wiggfle around a bit. “
I would also recommend wiggling the intensity of the light.
In case you’re not familiar with wiggle here is the basic structure:
wiggle(f, a); //f = frequency (how often) and a = amplitude (how much)You apply this to a property by adding an expression (opt-shift = or opt-click on the stopwatch) and typing the above code in (only replace f with your frequency and a with your amplitude).
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA
