Activity Forums Storage & Archiving Workstation 1151 /Adobe 4K /M.2/U.2/Gaming
  • Workstation 1151 /Adobe 4K /M.2/U.2/Gaming
    Posted by Kar Jas on October 6, 2016 at 9:11 am
    Hi!
    I would like to build a new workstation based on a 6700k, because Adobe currently barely with more than 4-6 cores can handle. I have a 3930k and a 2600k system.
    The 2600k-system from my homeoffice is now to give way. Since I am still surprised about the performance of my quads and it is also used for playing, I would like to again grow such a.
    Overclocking I’m moderate without water cooling. My 2600k has been stable for 4.4 years.
    Since I mainly After Effects and Premiere use a Geforce 980Ti is used, which I already have. Single GPU.
    32GB RAM are enough for me. 4×8> 2×16 because of quadchannel or?
    I have however difficulties to decide for the right storage and the mainboard ..
    1x 250GB SSD for Win7 / 10 and the programs
    1x 250GB for cache files
    1-2 TB performance for current projects
    (6TB HDD Backup Raid 1 internal / existing)
    Now I have lately tried to make the new interfaces smart.
    M.2, U.2, SATA Express
    For the system and backup storage is probably a simple SATA 600 connection.
    But what makes sense for my performance drives probably the most?
    Have different opinions on insufficient / shared lanes and associated performance losses read .. Too much heat development ..
    The graphics card should remain on 16x and should not be throttled.
    I would also like to use the new Thunderbolt 3 option. I get in my industry again and again hard disks with Thunderbolt and would like to take advantage of the advantage.
    Strangely, there are no details on the Thunderbolt support available on the manufacturer’s pages, but can be found in reviews. Are there any major differences in the Z170 boards? Some seem to need an extra adapter, while others run natively over the Type-C port or?
    The following boards I have so far filtered:
    ASUS Z170-WS https://www.asus.com/en/Motherboards/Z170-WS/
    ASUS ROG Maximus VIII Hero Alpha https://www.asus.com/en/Motherboards…II-HERO-ALPHA/
    ASUS ROG Maximus VIII FORMULA https://www.asus.com/en/Motherboards…-VIII-FORMULA/
    ASUS Z170-Premium https://www.asus.com/en/Motherboards/Z170-PREMIUM/
    GIGABYTE Z170X-UD5 TH GIGABYTE – Mainboard – Socket 1151 – GA-Z170X-UD5 TH (rev 1.0)
    GIGABYTE GA-Z170X Gaming 7 GIGABYTE – Motherboard – Socket 1151 – GA-Z170X-Gaming 7 (rev 1.0)
    I would be really grateful if you could help me. Thank you!
    Hi!
    Ich möchte mir eine neue Workstation auf Basis eines 6700k bauen, da Adobe aktuell kaum mit mehr als 4-6 Kernen umgehen kann. Ich habe ein 3930k und ein 2600k-system.
    Das 2600k-system aus meinem homeoffice soll nun weichen. Da ich immer noch über die Performance meines Quads überrascht bin und es auch zum Spielen verwendet wird, möchte ich mir wieder ein solches zulegen.
    Übertakten werde ich moderat ohne Wasserkühlung. Mein 2600k läuft seit 5 Jahren stabil auf 4.4.
    Da ich hauptsächlich After Effects und Premiere benutze kommt eine Geforce 980Ti zum Einsatz, die ich bereits habe. Single GPU.
    32GB Ram reichen mir aktuell. 4×8 > 2×16 wegen quadchannel oder?
    Ich habe allerdings Schwierigkeiten mich für den richtigen Storage und das Mainboard zu entscheiden..
    1x 250GB SSD für Win7/10 und die Programme
    1x 250GB für Cache Files
    1-2 TB Performance für aktuelle Projekte
    (6TB HDD Backup Raid 1 intern / vorhanden)
    Nun habe ich mich in letzter Zeit versucht über die neuen Schnittstellen schlau zu machen.
    Für das System und Backup-Storage reicht wahrscheinlich eine simple SATA 600 Anbindung.
    Aber was macht für meine Performance Laufwerke wohl am meisten Sinn?
    Habe verschiedene Meinungen über ungenügende/shared Lanes und damit verbundene Performance-Einbußen gelesen.. Zuviel Hitzeentwicklung..
    Die Grafikkarte sollte schon auf 16x bleiben und nicht gedrosselt werden.
    Ausserdem möchte ich die neue Thunderbolt 3-Option verwenden können. Ich bekomme ich in meiner Branche immer wieder Festplatten mit Thunderbolt und würde den Vorteil gern nutzen.
    Merkwürdigerweise sind auf den Herstellerseiten bei vielen Mainboards keine Angaben zu Thunderbolt-Unterstützung vorhanden, lassen sich dann aber doch in Reviews finden. Gibt es hier große Unterschiede bei den Z170er Boards? Manche scheinen einen extra Adapter zu benötigen, während andere nativ über den Type-C Port laufen oder?
    Folgende Boards habe ich bislang herausgefiltert:
    ASUS Z170-WS https://www.asus.com/de/Motherboards/Z170-WS/
    ASUS ROG Maximus VIII Hero Alpha https://www.asus.com/de/Motherboards…II-HERO-ALPHA/
    ASUS ROG Maximus VIII FORMULA https://www.asus.com/de/Motherboards…-VIII-FORMULA/
    ASUS Z170-Premium https://www.asus.com/de/Motherboards/Z170-PREMIUM/
    GIGABYTE Z170X-UD5 TH GIGABYTE – Mainboard – Socket 1151 – GA-Z170X-UD5 TH (rev. 1.0)
    GIGABYTE GA-Z170X-Gaming 7 GIGABYTE – Mainboard – Socket 1151 – GA-Z170X-Gaming 7 (rev. 1.0)
    Ich wäre Euch wirklich dankbar, wenn Ihr mir helfen könntet. Danke!
    Kar Jas replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
