Activity Forums Adobe Premiere Pro Workspace messed up at startup
  • Workspace messed up at startup
    Posted by Frank Feijen on February 11, 2015 at 1:52 pm
    Whenever I open Premiere, my workspace is completely messed up…
    Resetting the workspace works, but in the timeline of every sequence the video is scrolled up, so that I only see the audiotracks.
    Opening another project once premiere is opened: no problem.
    I’ve deleted the prefs: no improvement.
    Any clues?
    Rob Beauchesne replied 11 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Nils Welter
    February 11, 2015 at 7:21 pm
    It’s a bug. Go to The window menu – workspace and uncheck “Import workspace from projects”. This Works for me
    Nils Welter
    Adobe Certified Instructor – Premiere Pro
    CBC Cologne Broadcasting Center
    Cologne, Germany
  • Frank Feijen
    February 11, 2015 at 7:30 pm
    Wow, seems to do the trick!
  • Frank Feijen
    February 15, 2015 at 8:00 pm
    Okay….
    It doesnt make any difference after all. The problem remains persistent.
  • Frederik Bramming
    February 27, 2015 at 10:11 am
    Man, I’m getting the same problem every time I open Pr.
    I’m on windows 8.1 with Pr CC newest update.
    Have you found a solution?
  • Frank Feijen
    February 27, 2015 at 10:55 am
    Unfortunately: no.
    Haven’t found the time for a re-install, hoping that it will help.
  • Frederik Bramming
    February 27, 2015 at 12:20 pm
    Let me know if it helps. If not we should file a bug report at Adobe.
  • Frieder Noman
    April 29, 2015 at 3:59 pm
    did you find any solutiom for your messed up workspace at startup? Its the same on our four Workstations. Windows 8.1, Premiere Pro CC 2014.2.
    Frieder
  • Frank Feijen
    April 29, 2015 at 5:21 pm
    Sorry, did’nt find a solution. Even a reinstall of premiere doesnt help. And I’m not really looking forward to reinstalling windows…
    Guess I’m hoping that the upcoming update might fix something.
  • Rob Beauchesne
    July 29, 2015 at 2:24 pm
    Hello there. I am having an issue that I could use some help on. I have CS6 and working on a macbook pro. When I load my premiere pro project, after the
    splash page is finished, the loading page is to the left and half off screen,
    then after it gets done loading, my workspace is no where to be found. I still
    have the menu bar up top and if I push the space bar, I can hear the video but
    cant find the workspace. I have tried multiple things as far as resetting the
    workspace, hooking up a ext monitor but nothing seems to work. Have you ran
    across this at all? any help is greatly appreciated. Thank you in advance.
