Activity Forums Adobe After Effects Working with Zaxwerks ProAnimator
  • Working with Zaxwerks ProAnimator
    Posted by Brian Lynn on August 4, 2008 at 8:39 pm
    Using Zaxwerks to make a 3d clock… I can make the clock, that’s not a problem.
    The problem comes when I try to animate the hands to spin like a real clock. It doesn’t have to be a scaled time frame, though 12 hours will = 1 minute.
    ProAnimator has got to be about the most frustrating program I’ve used in a long time. It does great stuff, but its not very intuitive as to how to actually do things.
    I have all my objects in, and I am trying to spin just the small hand of the clock around a center point for now. So I figured out to leave the main clock pieces in place as a reference, make them invisible, and then when I “Rotate Around Common” it spins correctly. Without another object to relate to as “common” the small hand spins on its center axis. Fixed that one…
    So, now that I can spin the hands properly, I need to add “keyframes” at the start and end of my 1 minute…
    This is where I get extemely frustrated.
    Working with the timeline and animation controls is making me want to tear my hair out!
    I have a timeline, but clue how to add ANYTHING to it really. If I double click I guess I get a “Transition” which is very frustration because that is not the controls I need. But once I have a transition in place its almost impossible to get rid of it.
    If I can get rid of it, I sometimes get a different colored box that allows me to manipulate the object itself…
    Now, if anyone can tell me:
    #1 how to get rid of a transition. it keeps telling me “please select more than just a transition before deleting” which is confusing, what else am I supposed to select? I’ve got Transitions all over the place, I want them ALL GONE
    #2 how to get the box that allows me to manipulate the objects position, rotation, etc. consitently
    #3 how to set actual KEYFRAMES so I can tell my big hand I want it to spin so many degrees before 1 minutes up, and same with my little hand…
    Thanks to anyone who can help me!!
    I am using AE CS3 and the latest download of the Zaxwerks software.
    Brian Lynn
    Brian Lynn replied 18 years ago 23,811 Members · 1 Reply
  • Brian Lynn
    August 4, 2008 at 9:46 pm
    I would delete this if I could… I’ve figured out 99% of my own issues at this point. I guess I just need a LOT more time with this plugin =)
    Brian
