Activity Forums Apple Final Cut Pro Legacy working with wav files
  • Ben Insler
    April 10, 2007 at 4:35 am
    Yes it does. Does the file open in QuickTime? If so, try converting it to a 16 bit 48k .aiff and bring that converted file into FCP. If it doesn’t open in FCP or QT, the file may have been damaged on download.
    -Ben
  • Rafael Amador
    April 10, 2007 at 4:41 am
    You shouldn’t have any problem with .wave files in FC. However if you can not open it in FC, try to export it with QT as .aiff. 48Khz and 16 bits.
    Cheers,
    rafael
  • Lsmith
    Does not open in Quick Time or FCP. Thx for the response.
  • Rafael Amador
    April 10, 2007 at 4:45 am
    As Ben says, If you can not open it with QT the file may be damaged on downlaod.
    Rafael
