Activity Forums Adobe Premiere Pro Working with two monitors
  • Working with two monitors
    Posted by Joe Landau on June 28, 2005 at 3:57 am
    I just bought a laptop and also connected my old CRT to it. While editing video, is there any way to use both monitors and split the work among the two screens?
    Joe
    Rick Austin replied 21 years, 2 months ago 5 Members · 6 Replies
  • Aanarav Sareen
    June 28, 2005 at 5:17 am
    Yes there is. Make sure that Premiere Pro is not maximized and drag one end of the program onto the other screen. Should work fine.
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Redgum
    June 28, 2005 at 7:47 am
    Aanarav, are you sure this works with a laptop? Isn’t the VGA out a loop through, either or, or clone? Not necessarily a dual output?
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
  • Alex Udell
    June 28, 2005 at 3:37 pm
    It really depends on the gfx chipset….
    most laptops I’ve worked with suport extended desktops….
    With the second monitor attached,
    go to the desktop, right click and choose properties…
    choose advancde options and see what’s available…
    Alex Udell
    lead demo artist and trainer
    PEI Graphic Technology http://www.profileeast.com
    My Reel: https://alexudell.no-ip.biz
    COMBUSTION EXCHANGE FTP: ftp://combustionexchange.no-ip
    Logon: combustion_user
    PW: learn
  • Joe Landau
    June 28, 2005 at 8:43 pm
    Hi Anarav,
    I may miss the point. I did as you suggested, but both screens look exactly the same. The same desktop appears on both monitors.
    Joe
  • Alex Udell
    June 28, 2005 at 11:32 pm
    That’s because your defaul Desktop propoerites are set up for “mirroring”
    see above post and check to see if you can use an extended desktop…
    Alex Udell
    PW: learn
  • Rick Austin
    June 30, 2005 at 1:42 am
    1. Right click on desktop
    2. Go to Settings tab
    3. You should see the “2nd” monitor in the monitor icon area
    4. Click on the 2nd monitor.
    5. Check the “Extend my Windows desktop onto this monitor.” checkbox.
    If that checkbox is not available then your graphics card does not support or you may need to get a more recent driver. I’ve usedd this setup on my last two laptops and it worked great.
