Activity › Forums › Adobe Premiere Pro › Working with transparent PNGs in Premiere
  • Working with transparent PNGs in Premiere
    Posted by Darren Lee on August 2, 2020 at 4:55 pm
    I’m trying to work with transparent PNG in Premiere, here’s what it looks like in photoshop:
    and works perfect in After Effects on a black background:
    However, when i bring it into Premiere, it doesn’t seem to handle the detail very well:
    I’ve tried changing all the different depth settings in the sequence, but I don’t seem to be able to get anywhere. Is this simply because premiere doesn’t handle transparency / alpha as well as After Effects? Thanks
    Lesley Lotto replied 6 years ago 3 Members · 3 Replies
  • Daniel Carranza
    August 31, 2020 at 12:44 am
    Hello, Darren Lee!
    You could improve that by adding the Ultra Key effect on the png image. Then you could change the “Choke” and “Soften” properties of the effect. That will make the outine of your image much better. If you’re aiming to preserve the Alpha Channels (transparency) of your video, try exporting it with with AfterCodecs. You could choose the the following codecs: ProRes 4444, ProRes XQ, and ProRes 4444. You can find the plugin on http://www.autokroma.com/AfterCodecs.
    Let me know if you succeeded!
    To any moderator coming to my post: I’m not making any advertisement regarding products or whatsoever. I’m just trying to help a colleague by suggesting a possibility that would fix his problems and also help him to achieve a higher quality.
    Best wishes,
    Daniel Carranza
  • Lesley Lotto
    September 22, 2020 at 12:21 am
    can someone direct how to keep translucency from a png? I’m getting it turning to black from white!
    Don’t mean to hijack, but it won’t let me ask this because it’s too similar…
