Activity Forums Apple Final Cut Pro Legacy working with stills
  • working with stills
    Posted by Andrew Wise on December 1, 2005 at 4:43 pm
    Hi all,
    I’m woking on a project and want to superimpose photo elements over video.
    I’ve done the work in photoshop( cut out the elements and dragged them onto a new transparent image ) and saved as the default .psd. Upon import to FCP they open as sequences. I have approx. 30 of these photo elements that I wish to animate over the video. I am about half way through laying each one onto the timeline (approx. 15 done) when my Mac tells me it’s out of memory. I’m running a G5 with 512 MB of RAM. I can’t really understand why these 15 photos (sequences) are choking the system…I’m not running any other programs. Here are my questions…..1. does it sound ‘normal’ that this would choke a G5 running 512MB of RAM….and 2. Am I doing this the right way or the hard way? It does seem cumbersome to have to work with 30 sequences open on the timeline, but it’s the only way that I know how to do it if I want to work with ‘cut out’ photo elements’. Is there a better way?
    I’m stuck until I figure this out so I greatly appreciate any advice.
    PS…I don’t mind buying and installing more RAM, I just want to make sure I’m not overlooking an easy solution. Besides this problem, 512 MB has been working just fine.
    Thanks in advance,
    Andrew
    Andrew Wise replied 20 years, 9 months ago 4 Members · 6 Replies
  • Todd Beabout
    December 1, 2005 at 4:54 pm
    I’d go with more RAM anyways, but that’s just me. FCP can use up to 2 Gigs of RAM, and I bet I push that from time to time.
    As far as the Photoshop files… It gets on my nerves to have to deal with sequences on my timeline, unless I actually need to have the layers seperated in order to animate them or something. For that reason, I usually save as .tiff (no layers) out of Photoshop. Seems less intensive for FCP to deal with a flattened image vs. a layered file.
    Give that a try and see if it helps. And go get yourself some more RAM! =)
    -Todd Beabout
    Vazda Studios
  • Arnie Schlissel
    December 1, 2005 at 5:09 pm
    First, 512MB of RAM isn’t really enough for FCP v4 or later. For v5, 512 is the minimum, Apple recommends 2GB or more.
    Also, how big are your stills? If you’re working in a DV timeline, they shouldn’t be more than maybe 2000 pixels accross or 1500 pixels high.
    Arnie
    https://www.arniepix.com
  • Andrew Wise
    December 1, 2005 at 5:47 pm
    I appreciate the advice, but I still have the problem of not having the element cut out because when you flatten the image, it imports into FCP with a solid background. I guess what I’m looking for is a way to bring clean graphic elements ,without any background, into FCP without having to deal with (them turning into) sequences or with choma keying.
  • Todd Beabout
    December 1, 2005 at 6:00 pm
    Well… that’s not exatcly true. You can create an alpha channel in Photoshop for one thing, but just save a .tiff out of photoshop (preserve transparency) and pull that into FCP. You may have to mess with the settings a bit (I’m not a Photoshop expert), but I know it can be done because I use tiff’s with transparency every single day.
    I think your real problem, as I said earlier, is that you have photoshop files with layers. I think it’s the layers that are killing you. When you open one of those photoshop sequences is there only 1 layer in there? If so a quicker workaround is to literally grab that 1 layer from inside the photoshop nest and drag it into the viewer or bin (or copy/paste… so many ways to do this). Then you will have only 1 layer that FCP is looking at instead of another nested sequence.
    Give it a try and let us know what happens.
    -Todd Beabout
    Vazda Studios
  • Todd Gillespie
    December 1, 2005 at 6:37 pm
    Andrew,
    Todd (the other Todd) is correct about how to use .tiff files instead of .psd. I only use .psd if I need to break up the layers.
    .tiff OR .pict will keep your transparency. tiff is uncompressed and .pict is commpressed.
    Whenever I need to prep graphics for TV, I will create/modify with a .psd file. I will KEEP the .psd file AS IS. Then I will save a copy as a .pict file. Why? Well if I have a full .psd file, then I don’t really need an uncompressed .tiff file? If it’s wrong or need adj.; open up the .psd file and make another ‘save as’ .pict.
    To make your alpha channel in photoshop: apple click on the layer (it will highlight everything on that layer), then go to ‘Select’ pull down, ‘Save Selection’, (it should default to channel), click OK. DONE
    IF you have multiple layers that need to be alpha channeled, then you need to do a little more management of your layers. Once you have all the layers the way you want them create a new blank layer (make sure it’s highlighted), choose merge layers WHILE HOLDING THE OPTION BUTTON, this will merge all of your layers onto one layer. Then uncheck all of your layers except your merged layer. Then follow along with my first guide. DONE.
    Good Luck,
    PS You need A LOT more RAM.
    Todd at UCSB
    Television Production
  • Andrew Wise
    December 1, 2005 at 8:17 pm
    Thanks Todd (and everyone else who responded),
    I’m going to try the .tiff with preserve transparency and play with the alpha channels until I get something to work. It sounds like what I’m looking for.
    Thanks again,
    Andrew
