Activity Forums Apple Final Cut Pro Legacy Working with Red 2K 120fps in Final Cut
  • Working with Red 2K 120fps in Final Cut
    Posted by James Berry on July 21, 2010 at 7:50 pm
    Thanks to anyone in advance for your input.
    I’ve never worked with footage from a Red before and I have a pending project for which I’m trying to figure out the workflow.
    I have a client that wants to shoot some sports footage at 2K 120fps, so that they can get fairly decent slow motion in a 24p sequence with out having to rely on interpolation unless we need to. The final show is bound for the web, so I can bump down the rez and convert to QT, but need to retain the 120fps.
    Ideally, I want to be able to view and edit the footage in realtime (not slowed down) without rendering, but have access to the extra frames when we get to a shot that we want to playback slow. Is there a clean way to do this with Final Cut Studio?
    Also, we may have to take a sequence from FCP to After Effects for additional polishing and graphics.
    Any suggestions on file prep and workflow?
    Jim
    James Berry replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
