Activity › Forums › Apple Final Cut Pro Legacy › working with PNG sequence in FCP
Posted by Manuel F. rugeles on January 19, 2006 at 1:29 amHello everyone, I
Manuel F. rugeles replied 20 years, 7 months ago 2 Members · 2 Replies -
Debe
January 19, 2006 at 1:43 amTry importing the image sequence into QuickTime Pro. You should have QuickTime Pro as a part of Final Cut Pro.
Open up your image sequence and export it out using the same settings as your sequence in Final Cut Pro is and then you won’t have to render.
Hope this helps!
debe
Manuel F. rugeles
January 19, 2006 at 2:22 amAll right, thanks, I guess that is the best solution, I was wondering if that was posible without the need of exporting through quiktime, but you
