Activity Forums Adobe Premiere Pro Working with photoshop
  • Working with photoshop
    Posted by Christy Mahon on May 15, 2013 at 9:37 pm
    I’m new here and new to the Adobe Suite too, so feeling my way I might not be using the right language or using the best methods.
    I want to remove a table from the background in a PP film clip. My plan is to create a new background to lay under the clip and then to cut out the table from my clip.
    The background to replace the table will be made using a section of bare wall in the same clip.
    To get the bare wall under layer I want to import some frames into photoshop and make a PSD that I will then import back into PP and lay under the table clip.
    My question is, how do I get the frames from PP into Photoshop? Im using CS6.
    Thanks for your guidance
    Joseph W. bourke replied 13 years, 3 months ago 3 Members · 5 Replies
  • Joseph W. bourke
    May 15, 2013 at 11:18 pm
    Here’s the word straight from Adobe:
    https://help.adobe.com/en_US/premierepro/cs/using/WS6693F22C-C06E-431a-A634-62343C65BA7B.html#WS4AF3A4A1-D276-4f3b-A5B2-D3C19D3269DA
    If your camera is locked off in the shot, it would be possible to just grab a still, paint it in Photoshop, and bring it back in to Premiere Pro. Part of the workflow will depend on what the ultimate usage is: do you want to use this background to put something else on top (like a keyed object or person), or is it only the table which has to be removed, and that’s it? Also, depending on the format of your video, you might be able to just open it directly in Photoshop, retouch it, then render it off to use in PPro. As of CS5, Photoshop could import:
    • MPEG‑1 (.mpg or .mpeg)
    • MPEG‑4 (.mp4 or .m4v)
    • MOV
    • AVI
    • MPEG‑2 is supported if an MPEG‑2 encoder is installed on your computer.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Christy Mahon
    May 16, 2013 at 5:07 am
    Thankyou for responding Joe. Where I am stuck is that I cannot find a control in PP to export footage, or a frame, into Photoshop. I am looking for a specific pathway through the menu structure. All the docs seem to stop at big picture statements about what is possible, neglecting to set out the procedural steps.
    cheers
    Chris
  • Alice Queen
    May 16, 2013 at 9:38 am
    photoshop is too difficult to me. i wanna a similar but easier program panorama software. my only request is that it can make 360 panorama and 3d panorama. that’s it, thank you
    travelling and photography lovers. learning how to make 3d panorama and 360 panoramas! Keep myself happy everyday~~
  • Joseph W. bourke
    May 16, 2013 at 1:08 pm
    Use the Export Frame button which is right on either the Source or Program Monitor, or even simpler, the Shortcut Key, which is Ctrl+Shift+E for the PC, or Shift+E on the Mac.
    Here’s where the info on Export Frame lives in the help files:
    https://help.adobe.com/en_US/premierepro/cs/using/WSa41b87baf39dd9b0-6127dc1e12706029ce3-8000.html
    Joe Bourke
    Bourke Media
  • Joseph W. bourke
    May 16, 2013 at 4:36 pm
    You might want to try this:
    https://hugin.sourceforge.net/
    Joe Bourke
    Bourke Media
