Activity Forums Adobe After Effects Working with Photoshop Layers in AE
  • Working with Photoshop Layers in AE
    Posted by Andreas Sizynski on April 30, 2012 at 6:52 am
    I am trying to make an animated overlay using some photoshop layers.
    I imported the Photoshop file into AE, and I am already running into some problems.
    1) Each layer only has a run duration of 10 frames (frames, not seconds). I tried fixing this by setting the comp to the desire time (6 seconds @ 24 FPS) but the layers insist on their duration of 10 frames.
    2) Each layer insists on staying at 30 FPS playback.
    3) I want to animate a camera trucking in on the frames. Most animated overlays (using the 3D effect to create a multiplane effect) I have seen use a null layer–what is the difference between a null and a camera layer?
    I have searched other CreativeCow topics about this, but I am still confused, thanks guys!
    An Artist interested in the past, stuck in the present.
    Andreas Sizynski replied 14 years, 4 months ago 2 Members · 2 Replies
  • Chris Buttacoli
    April 30, 2012 at 2:25 pm
    Setting the comp to 6sec won’t increase the layers duration. You need to stretch the layers out manually.
    Having the comp at 24fps is what counts!
    A null is an invisible layer that when you parent a camera to it, it is easier to control.
  • Andreas Sizynski
    April 30, 2012 at 11:53 pm
    It doesnt seem to let me stretch the layers out.
    I tried to adjust the composition, but each layer insists on on remaining @ 30 fps.
