Activity › Forums › Apple Final Cut Pro Legacy › Working with multiple viewers
  • Working with multiple viewers
    Posted by Jack Fox on July 28, 2012 at 3:29 pm
    I have 3 streams in my sequence and would like to be able to see each in a separate viewer. The attached graphic shows one stream that displays properly, while the other streams (one above and the other below) do not follow the play head in the sequence. The only difference I notice is the small button on the top right of the viewer on the left side. (Notice the viewer on the right does not have that button and it does not follow the sequence playhead.) Does anyone know what that is (see attached), and how I can get the other streams to follow the sequence play head? Note that all viewers are set to “gang.”
    jmf
    Jerry Hofmann replied 14 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 28, 2012 at 8:31 pm
    The only way to see more than one layer at a time in a Viewer window is to create a multi clip and view the clips as angles. Only one Viewer window can be active at any given time.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jack Fox
    July 29, 2012 at 4:22 pm
    So what is that button my arrow is pointing at?
    jmf
  • Jerry Hofmann
    July 29, 2012 at 4:40 pm
    It’s a clamshell to put buttons in… just like the one in the upper right corner of the timeline window. Open the button list (option + j) to see all the lovely things you can do with it. Drag a button to the clamshell, then drag it off.
    Jerry
    Current DVD:
