Activity Forums Apple Final Cut Pro Working with Multiple Projects (timelines) in one Event
  • Working with Multiple Projects (timelines) in one Event
    Posted by Adam Berch on September 1, 2015 at 2:33 pm
    I am working on a project in FCP X 10.2.1. I have a project (Timeline) open and am working on it. I know you can make another project (timeline) and work on it as well When I’m gone with all of my projects (timeline) I make a new one and copy and paste all of the other timelines into the new one and make one finished project.
    Is this the easiest way to do this? I like to work on separate timelines during a project then make one final one at the end.
    When I close down FCP X after I’m done for the day, will I lose all of my projects?
    Thanks in advance
    Oliver Peters replied 11 years ago 2 Members · 1 Reply
  • Oliver Peters
    September 1, 2015 at 5:10 pm
    You’re fine. A lot of people work this way. When you close, you will not lose your timelines or the full session/project/production (Library in FCPX terms). The app constantly saves in the background so you almost never lose any work.
    Sometimes when you go back and forth between multiple projects in the timeline window, the timeline history occasionally drops some of the projects from its list (the left/right arrows); but, they are still in your Event browser. Just double-click to reload into the timeline window.
    A few different ways to work with multiple projects. First, you can simply create several different projects as segments of your edit and then copy/paste clips from each into a master project (as you described). Another way is to edit each separate project and then turn it into a compound clip, which is like a nest in other NLEs. Then edit these compound clips to a new master project.
    If you are working on multiple projects as versions of each other, then use “duplicate as snapshot”, which would be like doing a “save as”. Now you have two versions of that project, which can be edited independently without any dependencies between them.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
