Activity › Forums › Apple Final Cut Pro Legacy › Working with lower resolutions inside FCP
  • Working with lower resolutions inside FCP
    Posted by Infomanbri on May 29, 2006 at 1:09 am
    Hey all,
    I am re-editing a project that I did years ago on much less sophisticated hardware. In most cases, I have the original footage to go back to. But in some, the only thing I have are the original movie files which are in a much lower resolution than 720×480 (mostly 320×240).
    Knowing that the clips are lower quality, is there any filter or technique I can do inside of FCP to at least make them somewhat presentable and useable?
    Brian McCollister
    Chris Poisson replied 20 years, 4 months ago 3 Members · 3 Replies
  • Petteri Evilampi
    May 29, 2006 at 2:52 pm
    Scroll down in posts to “Resizer by Chris Poisson on May 24, 2006 at 8:49:07 pm”
    They are talking about this:
    https://www.digitalanarchy.com/resizer/resizer_main.html
    Generally I would say You are in serious trouble with Your resolutions…
  • Chris Poisson
    May 29, 2006 at 5:12 pm
    Actually, in the last few hours I have been enlightened to using Nattress chroma sharpen befor upscaling, which is beautiful and renders about four times faster than Resizer or Instant HD, which is another plug I’ve been foolng with this weekend. FYI
    Have a wonderful day.
  • Chris Poisson
    May 29, 2006 at 5:14 pm
    Ooops,
    Let me add that your 320×240 movies may have considerable compression via Squeeze or Cleaner or whatever, in which case uprezing with anything may be pretty tough, if not impossible.
