Activity Forums Apple Final Cut Pro Legacy Working with JPEGs in FCP
  • Working with JPEGs in FCP
    Posted by Rob Gee on May 24, 2005 at 9:07 pm
    I’m putting together a piece that consists of photos-only, and have imported them from a CD into the project, and then to the timeline. My problem is this: even after rendering, the photos display a “shimmering” or strobing, quality in the parts of the photos that are the brightest, or that have the thinnest lines.
    The photos were put onto the CD at decent resolution, an average of 500KB Is there something I can do to lessen this shimmering that I’m seeing?
    Thanks very much. – Rob
    Rob Gee replied 21 years, 4 months ago 5 Members · 5 Replies
  • Darrin J
    May 24, 2005 at 9:13 pm
    Yip, add a ‘flicker filter’.
    Highlight the clips in the timeline, then go EFFECTS / VIDEO FILTERS / VIDEO and chose Flicker Filter. I think deinterlace also works, but hopefully somebody more knowledgable than I pop’s along soon to verify that (or the difference between)
    Also check the images are the correct size. See Ken Stone’s site for loads of good tutorials:
    https://www.kenstone.net/fcp_homepage/fcp_homepage_index.html
    Powerbook 17 1.67 512meg 100gig FCP HD
  • Gunner Jones
    May 24, 2005 at 9:26 pm
    Typically, it is not a good idea to use JPGs unless that is their native codec. PICT, TIFF, PSD or PNG are good choices.
    Other than that:
    What is the frame size of these JPGs? Are they larger than 2 or 3 times of the DV Frame?
    If so, you need to resize them in PS to be just that.
    Use the flicker filter or a little bit of gaussian blur to attack the “shimmer”.
    G.
  • Lee Burrows
    May 24, 2005 at 9:35 pm
    Rob,
    Flicker Filter works great on Freeze Frames from video and will help stills but the best filter to get rid of the shaking is to go under the effects tab or the way Darrin told you. Under Video Filters and open the Quicktime folder(4th from the bottom, I believe) and choose the blur filter, drag this over your shaking, strobing images and this will help. Double click the clip in the sequence and click the filter tab of the clip. You can choose how harsh to make the blur. 1 being the least and 7 being the most(you’ll probably never use this high of a setting). I usually have to use between 3-4 and that seems to still gives me a nice image without the shakiness. You have to choose what will work for you that doesn’t blur the image to bad or hurt the quality while getting rid of the shakes. In the future try to have the images resolution scaled down a bit to avoid this problem. Its those good ol’ photos prepared for print that are to strong for broadcast:)
    Good Luck
    Lee
    G5 Mac OS X
    Dual 2.0 Ghz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G4 Mac OS X
    Dual 1.25 Ghz
    FCP 4.5 HD
    Lacie Drives 200 Gbs
  • Jp Driscoll
    May 25, 2005 at 3:36 pm
    Also use your scopes to check the levels of the pictures. If the bright spots are too bright, you can get a lot of strange effects. You may need to knock the luminance down just a bit.
    JP Driscoll
    WDAY TV
    Fargo, ND
    “Television! Teacher, mother, secret lover.” ~Homer Simpson
  • Rob Gee
    May 25, 2005 at 5:43 pm
    Thanks for all your answers, guys. VERY helpful. A Quick Time blur/FCP Flicker did a nice job of bringing it down.
