Working with HDV / IMX / Dv and outputting it
Hi there,
I’m working on a project witch uses HDV, DV, IMX 625/50 footage and converted Mpeg’s (PAL).Now I have a problem with Upper & Lower fields. (Shift Fields?)
I also have to go to a SD output.(downconvert HDV?)
What will be the best way to setup my sequence as most of all footage is in HDV?I can’t do a rebatch, because all the footage is in the UK.
Regards, SAS
