Activity › Forums › Apple Final Cut Pro Legacy › Working with HDV and mini DV
  • Working with HDV and mini DV
    Posted by Phil Beastall on June 24, 2008 at 9:19 am
    I’m currently editing a video which was shot on HDV (1440×1080) and mini DV (720×576 Anamorphic)
    I’m currently slicing it together in a DV Pal 720×576 sequence, which has the letterbox black bars, but when it comes to the final output, what sequence settings would I need to put it to, considering the different dimensions and compression? And the fact that I won’t want the black bars on output but will mark it was 16:9 for the DVD authoring.
    Is the way that I’m editing at the moment a good way to do it or is there a better way of slicing together without compromising quality?
    Phil Beastall replied 18 years, 3 months ago 2 Members · 2 Replies
  • Tom Wolsky
    June 24, 2008 at 12:04 pm
    “I’m currently slicing it together in a DV Pal 720×576 sequence, which has the letterbox black bars”
    This is wrong. It sounds like you are editing in a 4:3 sequence and not an anamorphic PAL sequence. Make a new sequence that’s 16:9 and copy and paste the contents of the 4:3 sequence into the correct anamorphic sequence. You will then have to remove the distort attributes of all the clips.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Phil Beastall
    June 24, 2008 at 12:19 pm
    OK I’ll give that a go. Fortunately I haven’t done much, and was waiting for the advice. What would you suggest when it comes to the final output. The HDV is a lot larger than the Mini DV footage. Would it be be best to keep it at 1024×576, and shrink the HDV footage? I’m not too familar with upgrading. Would I need to upgrade the mini DV footage up to the size of the HDV?
