Activity Forums Apple Final Cut Pro Legacy Working with HDV 1080 60i for SD NTSC output
  • Working with HDV 1080 60i for SD NTSC output
    Posted by Sung Moon on August 12, 2009 at 5:04 am
    I have HDV footage: shot with Z-1, 1080 60i, 1440*1080
    I need to edit this for SD output.
    What I’ve been doing, which my previous editor had done, is like this:
    First, we capture as it is, which is HDV 1080 60i
    Then, for some reasons such as storage problem, we downconvert this to 720*486 in FCP using Quicktime conversion. and option we set is Apple Proress 422(HQ)/NTSC 720*486(16*9).
    After this, we reimport this into FCP. We make SD sequence and drop it into this sequence.
    However, I found that as soon as we drop mov into SD sequence, it becomes 4:3, which I assume natural. The problem is that I still want mov to keep its aspect ratio, 16:9.
    Is there anyway where it make letterbox automatically? Should I manualy squeeze the footage?
    So, I don’t know if my question above would make sense. In sum, I’d like to know the proper workflow when I work with HDV 1080 60i footage for SD output.
    Sung
    Sung Moon replied 17 years, 1 month ago 2 Members · 2 Replies
  • Nick Derrico
    August 12, 2009 at 6:57 pm
    Right-click on the clip in the Browser
    Go to Item Properties
    Format…
    Click next to Anamorphic, a check mark should appear
    Click OK
    That should make the clip widescreen, which when dropped into a 4:3 sequence should automatically letterbox it.
    Hope this helps!
  • Sung Moon
    August 13, 2009 at 6:47 am
    thank you so much. it helped me.
