Activity Forums Adobe Premiere Pro Working with HD
  • Working with HD
    Posted by Brebos on October 31, 2005 at 4:04 am
    Im very new to premiere pro, and have an hd question. So i downloaded a csi miami video, its an hd, and when i open it up in premiere pro it will not render or display and frames or audio. Its just flatline. BUT!!! when i make the preview dual view and i drag it across in the left preview window it will play just like it does in media player. Why can i not edit the video? Ive even tried to render it on the time line which takes like half a day for a one hour vid but still no results. $1000000 to whoever can help…lol
    Mike Velte replied 20 years, 10 months ago 2 Members · 3 Replies
  • Mike Velte
    October 31, 2005 at 1:02 pm
    From Premiere’s menu bar; File: Get Properties for (and select that HD file).
    Copy/paste that info in a reply here.
  • Brebos
    October 31, 2005 at 6:51 pm
    Thanks for trying to help! The properties are:
    Type:Avi
    File Size: 350 megs
    Image Size: 624 X 352
    Pixel Depth: 12
    Fram Rate 23.98
    Audio: 48000 hz
    Total Dur: 42:48
    Average Data RAte: 139.84KB/sec
    Pixel Aspect Ratio: 1.000
    AVI File details:
    1vid and 1udio
    Interleave: 1 : 0.58
    Video Track 1:
    1407 keyframes, 60175 delta frames
    Framerate 23.98
    frame size 624 x 352
    Depth 12 bits
    Compressor: ‘XVID’, Xvid MPEG-4 Codec
    Audio Track 1
    Size 40 megs
    Rate is 48000samples/sec
    Sample size 16 bits
    Campatible compressor: MPEG Layer-3 Codec
    Compression ratio is 34.82:1
    Additional information:
    VirtualDub
  • Mike Velte
    October 31, 2005 at 7:48 pm
    Your file is not HD, but a cut down SD file. The big problem is that the video compressor is Xvid and not supported by Premiere.
    You may have luck using VirtualDub to make a dup using another codec.
    Premiere Elements 2.0 is supposed to be able to open all codecs installed on your system.
