Activity Forums Adobe After Effects working with hd 720p60
  • working with hd 720p60
    Posted by Chinaski on August 16, 2007 at 1:43 am
    hi all.
    did a search and couldnt find anything about this specifically.
    apologies in advance if this is a dumb quesion- i’m fairly new to this….
    i have a quicktime that was exported from final cut- DVC PRO HD 720p60 1280 x 720 (1.33:1) 23.976 fps. Imported into AE and made a comp by dragging onto the comp button- settings seem fine. when i view it in the comp it has jagged diagonals and doesnt look as sharp as the original- it looks fine when i look at it in the footage viewer. Isn’t this not suposed to have fields. It interprets it with /sepreate fields- off/ by default.
    i need to get this back to the final cut pro editor and i want to look as good as it did before i got my hands on it. if anyone could shed some light on this it would be greatly appreciated.
    thanks
    Kevin Camp replied 19 years, 1 month ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    August 16, 2007 at 1:06 pm
    Seperate Fields should be off, so you’re OK there.
    Just ensure that the layer is set to Best Quality and Comp View is set to Full Rez. & Max quality.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Danny Princz
    August 16, 2007 at 1:23 pm
    do you have the pixel aspect correction turned on?
    this makes your footage look correct (ie not stretched) but is only a preview and not the best quality.
    if you disable the correction the footage should look fine.
  • Kevin Camp
    August 16, 2007 at 1:46 pm
    i think that it is probably the pixel aspect correction, turning that off (as mentioned) would help. also setting the comp to 1280×720 and square pixel would help, that’s normally how i work with dvcprohd footage.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
