Activity Forums Apple Final Cut Pro Legacy Working with .h264 in Final Cut
  • Working with .h264 in Final Cut
    Posted by Cameron Campbell on May 5, 2008 at 1:30 am
    Question for the forum:
    Anyone import and use .h264 files in Final Cut?
    I tried to import .h264 files in FCP 5.1.4 and it gave me the error ‘File Error. Unknown file.’
    Is there something I’m missing?
    Is there an upgrade that will recognize this file type?
    Or is this something Final Cut Studio 2 will recognize?
    Thanks for your time in advance!
    Regards,
    CAMERON CAMPBELL
    LUSTRE Communications, Inc.
    110 Union Street, Suite 510
    Seattle, Washington 98101
    Office: 206.622.0486 x201
    Fax: 206.622.0487
    Mobile: 206.953.2194
    <https://lustrecommunications.com>
    Mpigott replied 12 years, 6 months ago 17 Members · 26 Replies
  • 26 Replies
  • Tom Wolsky
    May 5, 2008 at 1:36 am
    H.264 is a delivery format, not a production format. You need to convert the media into a suitable format. What that is depends on what the files are and what their frame size is.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Cameron Campbell
    May 5, 2008 at 2:10 am
    Thanks Tom.
    The only problem is that the client supplied a major amount of footage in .h264 and, although this is clearly not the ideal format, this edit is only for a new business pitch.
    With this said, is it at all possible to work with .h264?
    Thanks again for you time.
    Regards,
    CAMERON CAMPBELL
    Fax: 206.622.0487
    Cameron Campbell
    Seattle/NYC
  • Walter Biscardi
    May 5, 2008 at 2:13 am
    [Cameron Campbell] “With this said, is it at all possible to work with .h264?”
    In FCP 6.0.2 you can simply drag in the first clip to a Sequence and FCP will automatically set up a timeline to match your footage. BUT H.264 is notorious for crashing and locking up FCP often. As Tom notes, this is a finishing format, not an editing format.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • David Peralta
    May 5, 2008 at 2:29 am
    if you’re looking to convert a bunch and you said quality isnt an issue, just use mpeg streamclip and convert to whatever codec you want to edit with, easiest is probally DV-NTSC.
    hmm… I wonder what this button does…
  • Zak Mussig
    May 5, 2008 at 3:03 pm
    I feel like this is one of those instances where you should go back to the client and tell them how their delivered assets affect your process. There’s definitely going to be some more time involved on your end whether it be transcoding or rendering, and your system performance probably won’t be great if you try to edit the h.264 natively.
    More time means more money, so maybe the original source will magically become available to you (assuming this wasn’t just shot on some consumer avchd camera), or at least extra charges won’t come as a surprise to them later.
    I’ve had several instances in which a DV tape “turns up” after I explain to a client the extra time involved when they give me an avi, MPEG2, or some other non-FCP friendly file.
    Zak
  • Tom Brooks
    May 5, 2008 at 4:44 pm
    There are probably variations of H.264 that are unknown to Final Cut, although in general, it should recognize most formats that Quicktime itself recognizes. Looks like some experimentation and batch converting are in order.
  • Gary Adcock
    May 5, 2008 at 5:04 pm
    [Tom Brooks] “There are probably variations of H.264 that are unknown to Final Cut, although in general, it should recognize most formats that Quicktime itself recognizes.”
    no.
    sorry- FCP is an editing program and there are many format that FCP cannot see, even with the WMV drivers from Flip 4Mac, there is NO way that I can edit in that codec.
    WMV and h.264 are delivery codecs, and there are even less useable in FCP than Mpeg2 files.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Tom Brooks
    May 5, 2008 at 7:31 pm
    [gary adcock] “no.”
    Tell Apple that. It works in a pinch. The codec isn’t the problem. If the specific H.264 movie you have is rejected by FCP, you’ll have to change it. Might’s well change it to a standard editing format.
  • Jason Porthouse
    May 6, 2008 at 9:01 am
    As you’ve probably gathered by now, H264 and FCP don’t play nicely together.
    I guess it all depends on how much is a major amount. I’ve used Compressor and MPEG Streamclip to convert fairly hefty amounts of footage – just set a batch process and leave your machine on overnight, or over the weekend. That’s the only way if you can’t get the original source….
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Marcela Canavarro
    May 9, 2008 at 6:34 am
    Hi all!
    Which format is better/easier to convert to an editing format: AVI or H264?
    cheers
    Marcela
Page 1 of 3
