Activity › Forums › Adobe After Effects › Working with fields (mixing 3D with motion graphics)
  • Working with fields (mixing 3D with motion graphics)
    Posted by Kristian Carey on October 16, 2008 at 12:12 pm
    Having not worked with fields in some time I was wondering if this workflow is correct for compositing field rendered 3D and motion graphics.
    1. Create new comp (in this case D1 720×486 .9)
    2. Import 3D renders (interlaced from 3Ds MAX) and set interpolation to lower fields
    3. Add misc text and motion graphics etc.
    4. Render footage at 720×486 and check Field Render to Lower field first
    Does this correct?
    So in this method, when I interpret footage and render to fields the output should be identical to the original interlaced source?
    Kristian Carey replied 17 years, 11 months ago 3 Members · 3 Replies
  • Mark
    October 16, 2008 at 2:33 pm
    This would be good for a TV output…for a web based output you should render out without fields, but you should always correctly interpolate imported footage.
    Mark.
    PS…lower field is good for NTSC SD
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Brendan Coots
    October 17, 2008 at 5:22 am
    Rendering interlaced out of a 3D package? Doing so throws away half your available resolution and seems a little pointless (may shave a few seconds off the renders, but still…).
    That said, your settings breakdown is correct.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Kristian Carey
    October 17, 2008 at 12:28 pm
    All of this is for broadcast (DVD), so what would you recommend for the 3D scenes – no fields?
