Activity › Forums › VEGAS Pro › Working with different resolution video
  • Working with different resolution video
    Posted by George Lemos on May 19, 2011 at 1:10 pm
    I’m working on a project that has a few people involved. We’re assembling the project in sony vegas. I’ve done a few test renders, and put them on youtube in HD widescreen format. However I am noticing an issue with some of the videos files used by the team with different resolutions.
    One person filmed in 1920 x 1080, while another persons resolution is some werid value like 1904 x 1134.
    When I add the 1904 x 1134 clips into Vegas, and play them, the black bars are visible on those videos, but not the clips imported that used the 1920 x 1080 resolution.
    SUGGESTIONS? What technique, or tutorial do I need to research to better work around this issue?
    Nigel O’neill replied 15 years, 4 months ago 3 Members · 3 Replies
  • Mike Kujbida
    May 19, 2011 at 2:11 pm
    I’ve never heard of 1904 x 1134 resolution.
    What kind of camera gives you that?
    A workaround is to open Pan/Crop on each of these clips, right-click and select “Match Output Aspect”.
    This should eliminate the black bars, hopefully without affecting anything else in the video.
  • George Lemos
    May 19, 2011 at 6:50 pm
    Fantastic, that easy little step did it. As for the ratio, not sure, I only received the video and did not ask how it was filmed. Thanks again.
  • Nigel O’neill
    May 20, 2011 at 3:15 am
    I agree with Mike. Note that excessive panning and cropping of video can result in some artefacts that make the footage appear to wobble or jitter.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
