Activity Forums VEGAS Pro Working with different frame rates
  • Working with different frame rates
    Posted by James Souter on March 14, 2011 at 4:23 am
    Hi All
    I’m in a situation where I need to edit up to four different types of footage in the one video. The sources are as follows
    Sony Cam – Sony AVC HD 1080 60i (AKA Pal 25 interlaced)
    Gopro Hero – AVC HD 1080p 29.97
    Gopro Hero – AVC HD 720p 59.94
    5d Mark II – Can’t remember format but frame rate is 24.976
    With the project set up to render to progressive 25 pal which I normally use for the Sony Cam only the Sony Cam (25 Pal) looks correct. All other footage has a degree of ghosting which is obviously because it’s been forced into a non native framerate.
    What options do I have available to me to minimise this issue? My guess would be to convert everything into the correct framerate first using a third party app and then work on the project.
    Regards
    James
    James Souter replied 15 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    March 14, 2011 at 12:45 pm
    Why are you using all NTSC cameras for a PAL project? You should really use PAL cameras for PAL delivery.
    You can right-click on each event and Disable resampling. That will eliminate the ghosting becasue it tells Vegas to stop resampling and blending the frames. The output may look a bit jerky but it is what it is.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Souter
    March 14, 2011 at 12:56 pm
    Thanks John. I was thinking about trying that tonight so I’ll give it a go. The majority of the footage is PAL and the other cameras are used for a specific purpose. The gopro is a tiny waterproof sports camera which can be mounted on cars, skies, heads, you name it. The 5d needs no introduction but I’m using it for its depth of field
