Activity Forums Apple Final Cut Pro Legacy working with different format
  • working with different format
    Posted by Michal Yaniv on April 25, 2010 at 11:46 am
    I need to know the correct work flow in a project with 2 different format, which is: DV-PAL 720*576 25fps and HD XDcam 1920*1080i50 25fps
    Some say that I have to convert everything to prorez befor start editing. some say – don’t convert.
    what kind of sequence setting I should use?
    should I export everything as PAL or HD?
    The end product should be a 50 min movie, on a regular DVD (for home use).
    So many questions….
    I’ll be happy to know the correct work flow for projects like this.
    Thanx,
    Michal
    Michal Yaniv
    http://www.avocadofilms.info
    Michal Yaniv replied 16 years, 4 months ago 2 Members · 4 Replies
  • John Fishback
    April 25, 2010 at 3:31 pm
    You’ve got two very different formats. My suggestion is to edit in HD and uprez the DV footage using Compressor. There’s plenty of discussions how to do that if you search the Cow. I’ve never edited with XDCAM before so I don’t know the recommended workflow.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Michal Yaniv
    April 25, 2010 at 3:45 pm
    Hi John,
    thank you for your quick answer.
    I know those are 2 complitly different formats, and actually I believe that this is how hell looks…
    anyway, if I want to uprez the DV stuff with compressor, do you know the setting I should use?
    Michal
    Michal Yaniv
  • John Fishback
    April 25, 2010 at 5:02 pm
    Checkout this thread. You’ll find more info if you search for uprez HD or similar.
    John
  • Michal Yaniv
    April 25, 2010 at 6:14 pm
    Hi John,
    thanx again.
    it was useful
    Michal
    Michal Yaniv
