Activity Forums Adobe Premiere Pro Working with different format videos.
  • Working with different format videos.
    Posted by Cassandra Hellberg on October 12, 2015 at 8:45 pm
    Hey there!
    Firstly im new to creative cow, secondly im new to Premiere Pro CS6 and video editing. I have been reading some other posts, related to the same topic but im still a little confused as what to do. Im working on two different video formats. One was with a very shitty photo camera, and the other, a great video camera.
    These are the formats:
    Type: QuickTime Movie
    File Size: 8,1 MB
    Image Size: 640 x 480
    Frame Rate: 30,00
    Source Audio Format: 11024 Hz – 8 bit – Mono
    Project Audio Format: 11025 Hz – 32 bit floating point – Mono
    Total Duration: 00:00:07:00
    Pixel Aspect Ratio: 1,0
    Type: MPEG Movie
    File Size: 648,0 MB
    Image Size: 1920 x 1080
    Frame Rate: 29,97
    Total Duration: 00:03:46:10
    Possible, to combine the two into one format? This video will be made for online use. possibly dvd too…
    Thanks!!!
    Cassandra
    Irene Sinou replied 10 years, 10 months ago 4 Members · 5 Replies
  • Jon Doughtie
    October 12, 2015 at 9:22 pm
    It looks like you have one standard def file and one high def file. So if you would like the material from both to fill the screen, you have two options.
    1 – Make a standard def timeline based on the first clip. Scale down your second HD clip until it fits top-to-bottom in the composition. The left and right edges will be cut off, because the aspect ratio of your SD clip is 4:3, and your HD clip is 16:9.
    2 – Make a high def timeline based on your second clip. Scale up your first SD clip until it fits either top-to-bottom or left edge-to-right edge. It will not look great, because you have to blow up standard def video. If you make it fit top-to-bottom, you will have black bars on the left and right of the screen, again because of aspect ratio mismatch.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Cassandra Hellberg
    October 15, 2015 at 7:25 am
    Thanks a ton! Will try out your advice and get back to you! Thanks a lot!
  • Irene Sinou
    October 26, 2015 at 6:28 pm
    Hey there,
    I’m also new to Premiere (I normally edit on Final Cut).
    And am wondering what is the best working format with Premiere (equivalent to ProRes).
    I’ve got a bunch of filming format to edit and I’d like to work on a single format…
    Thank’s so much
    I.
  • Andrew Kimery
    October 26, 2015 at 8:18 pm
    [Irene Sinou] “And am wondering what is the best working format with Premiere (equivalent to ProRes).
    I’ve got a bunch of filming format to edit and I’d like to work on a single format… “
    PPro doesn’t have a de facto format to work in. You could change everything to ProRes or DNxHD or Cineform… whatever you want (that ideally runs well on your machine).
  • Irene Sinou
    October 28, 2015 at 6:42 am
    Thank you so much Andrew for your answer. It’ll be in prores to start with while discovering the specifities of ppro…
    Have a nice day.
    I.
