Activity › Forums › Apple Final Cut Pro Legacy › Working with Canon T2i footage in FCP
  • Working with Canon T2i footage in FCP
    Posted by Emin Bassavand on December 2, 2010 at 5:24 am
    Hey everyone, i know this questions been asked a million times but the fixes that work with everyone don’t really work with me
    So on my MacbookPro (2.2 ghz intel duo, 2gb RAM, OSX 10.4.11) i have some files from a Rebel T2i (shot in 1080p 24fps). So from what i understand i need to convert these to ProRes or some other FCP friendly file format. (i’m working with FCP 6.0.6 btw). I have used both Compressor and MPEG Steamclip to convert the files to ProRes but when i import them to Final Cut they become extremely choppy and impossible to work with…
    Does anyone know what i’m doing wrong here?
    Ashley Harvey replied 15 years, 10 months ago 5 Members · 10 Replies
  • 10 Replies
  • Zane Barker
    December 2, 2010 at 6:21 am
    You say they play back choppy, give us some info on the drive you are editing off of, like hoe is it connected to the computer.
    **Hindsight is always 1080p**
  • Emin Bassavand
    December 2, 2010 at 6:31 am
    the .mov files from the t2i are on my external harddrive (connected with USB), but when i converted them to ProRes i put them onto my desktop (just to test it out)… so im working from my internal harddrive.
  • Phil Balsdon
    December 2, 2010 at 7:52 am
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Works almost the same for FCP 6.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://www.steadi-onfilms.com.au/
  • Emin Bassavand
    December 2, 2010 at 8:53 am
    thanks for this, but i’m using OSX 10.4.11 and according to Canon’s website the minimum requirement for the final cut EOS update is OSX 10.6.4 or later
    and plus i no longer have access to the card. all the video files are saved onto my external harddrive
    MacBook Pro 2.2 Ghz Intel Core 2 Duo. 2 GB 667 MHz DDR2 SDRAM. OSX 10.4.11
  • Paul Jay
    December 2, 2010 at 9:18 am
    You need a dedicated media drive. Get a firewire harddisk to playback your ProRes media.
  • Zane Barker
    December 2, 2010 at 3:29 pm
    [Emin Bassavand] “the .mov files from the t2i are on my external harddrive (connected with USB), but when i converted them to ProRes i put them onto my desktop (just to test it out)… so im working from my internal harddrive.”
    Two rules of editing video to prevent dropped frames when editing. 1 Don’t edit from a USB drive, USB works in bursts of data so it cannot always keep up with the high data rates needed for video. 2 Don’t edit from your system drive. That drive already has enough to do running the OS and Apps.
    Use an external FireWire Drive at the least.
  • Emin Bassavand
    December 2, 2010 at 6:00 pm
    Thanks Zane! i’ll grab a firewire cable and hopefully that’ll work
  • Phil Balsdon
    December 2, 2010 at 8:29 pm
    When you copy / duplicate the camera card footage to your drive you need to copy everything not just the video files.
  • Emin Bassavand
    December 2, 2010 at 11:13 pm
    yeah… i think this is the main problem… i stupidly used iphoto to bring in my files… just a dumb move on my part. i’ll use a card reader from now on, hopefully thatll do the trick
  • Ashley Harvey
    December 3, 2010 at 6:16 pm
    Hey guys, I hate to jump in here, but I have been scouring the web and this thread is the closest I could find to being even remotely close. I am running an ancient FCP system (FCP HD 4.5 on a G4 Quicksilver 933MHz with only 1 gig RAM – OSX 10.4.11. All drives used for media are external Rocstor firewire drives.) I have been using it to edit DV video for years with great results, however my Sony TRV-900 finally gave up, and I recently got a Canon T2i. I am trying to figure out how to get these two to work together so I can go on editing video. Its not for on-air, just personal use, but I cannot seem to find an answer anywhere. Everyone is recommending using the AIC or PRORES codecs, but my software does not have them, and as far as I can tell, I cannot get them seperately – only if I upgrade my FCP version which is not an option for me. Any small bone tossed my way would be greatly appreciated… even if just to tell me I am screwed 🙂
