Activity › Forums › Adobe Audition › Working with audio from 24 FPS Video
  • Steven Talley
    February 18, 2009 at 4:15 am
    Is this audio file a lossless wave file?
    What is the bit rate and sample rate of the original file?
    Are you maintaining these as you export the audio?
    Are the file time length’s the same for the original and the rendered file?
  • Scott Smitelli
    February 22, 2009 at 2:25 pm
    Also, is the video running at “true” 24 FPS or at 23.976? That type of discrepancy will cause a slight drift (~1.4 frames per minute) that can add up over time.
